Home › Forums › Problems and solutions in GDL › Doors and windows › Accessing all door parameters
- This topic has 3 replies, 2 voices, and was last updated 2 years, 1 month ago by
Barry Kelly.
March 25, 2020 at 22:26 #18649
Frank Randel
ParticipantI’m jumping from v18 to 23 so please be patient. I’d like to add some custom parameters to the standard commercial door that can be edited and later show up in the door schedule. In 18 you could display an entire list of all the parameters under ‘Parameters for listing’ including ones that were added. That’s disappeared in V23. How do I get that back?
March 26, 2020 at 02:34 #18650
ParticipantThere is probably a HIDEPARAMETERS ALL command in the script.
Comment that out and the parameter list should be visible to the user.Barry.
March 26, 2020 at 14:39 #18653
Frank Randel
ParticipantUnfortunately there isn’t a HIDEPARAMETER command. All the scripts in the door are blank except the Master script and there is no HIDEPARAMETER command in there. I was able to create a work around that I’ll experiment with more. I created a new title down at the bottom of the parameters list and placed in a few test variables below it. Then back in the master script I used the HIDEPARAMETER ALL command with my new title in quotes after the ALL and my new variables show up and can be edited.
So while your suggestion didn’t work, it did help me start down the path to get where I need to go…. I think.
March 27, 2020 at 02:40 #18655
ParticipantThen back in the master script I used the HIDEPARAMETER ALL command with my new title in quotes after the ALL and my new variables show up and can be edited.
Yes if you add parameter names after the ALL then they will show.
HIDEPARAMETER ALL – will hide ALL parameters
HIDEPARAMETER ALL [“name1” [, “name2”, …, “namen”]] – will hide ALL parameters except name1, name2, etc.
When you say all the scripts are blank except the master script, are they all empty or are the script buttons locked.
They may all be empty as the master script is CALLing another macro that has al the scripts.
The GS objects do a lot of CALLing other macros so it can sometimes be a bit tricky to follow exactly what is going on.Barry.
