Home › Forums › Problems and solutions in GDL › GDL add-ons › Blocking the descriptions
- This topic has 6 replies, 3 voices, and was last updated 7 years, 1 month ago by
Vojtěch Janda.
July 2, 2019 at 12:45 #4817
Vojtěch Janda
ParticipantHello,
please, how I block the descriptions of gdl object (for example 3D description, 2D description, properties etc…) as shown in the picture?Attachments:
Vojta
July 3, 2019 at 03:48 #4819
ParticipantYou mean how do you unlock the scripts?
You don’t – or at least you are not meant to.
The author of the object has deliberately locked them so they can’t be accessed.
Contact the author of the object to see if they will allow you access and if so they can send you an unlocked version.Barry.
July 11, 2019 at 14:39 #4835
Vojtěch Janda
ParticipantI mean how to lock the own object descriptions.
Thank you.
VJ
Vojta
July 11, 2019 at 16:02 #4836
ParticipantThere are 2 ways: There was an old tool called “hidescripts.exe” but I don’t know if there are actual versions of it.
2nd: You can do it with the XML-Converter.4.3 Hiding script sections: Library Parts provide a way to have the scripts hidden from the end user. This can be done in XML by adding 64 to the SectionFlags attribute of the script to be hidden. This will create a GSM file with the given scripts hidden. Converting a library part with hidden scripts back to XML will create empty script elements, so be sure to keep the original XML files after publishing the library.
MAC OSx 10.14 -
July 11, 2019 at 16:04 #4837
ParticipantAnd you can manually protect your whole object with a password in the GDL editor …
MAC OSx 10.14 -
July 15, 2019 at 04:06 #4844
ParticipantSorry, you actually want to hide the scripts.
As Joachim mentioned, there is an old ‘Hidescripts.exe’ program that will lock the script buttons as shown in your image.
It is very old (still works) and I think it can be found in the library developers kit (but I am not 100% sure).It is no longer needed now as the GDL objects have an option to set a password when saving.
The objects can only then be opened with that password – so don’t lose it or keep a copy of the original object saved without a password.Barry.
July 15, 2019 at 13:23 #4845
Vojtěch Janda
ParticipantOk thank you very much. I thought, that locking the script is news. I use the password locking.
Vojta
- The forum ‘GDL add-ons’ is closed to new topics and replies.
