Custom Door/Window Marker
This topic contains 4 replies, has 2 voices, and was last updated by  Peter Koncz 3 years, 9 months ago.
  • #2452
    Peter Koncz
    I was looking all over the web on how to customise 2D door/window markers. In Hong Kong, it has to be and extended Hexagon shape that fits the text. The text is made up of 3 segments:
    Type Code (W/L/G) + Floor Number + ID, for example W001 means Window, O. Floor, 01 as ID.
    First question: how do I modify the standard hexagon shape into an longer, extendable hexagon?
    BIM manager at Leroy Street Studio, New York, USA
  • #2459
    Peter Koncz
    Guys, I have created this simple door marker, but I cannot get the text size defined… It stays the default 500mm.
    Thanks,
  • #2462
    Please attach the gsm file in zip.
  • #2463
    Peter Koncz
    Finally I have figured out and able to set model size and paper size using SET STYLE, DEFINE STYLE and TEXT2 commands.
    I have uploaded the GSM files, you can take a look, if you have time. Thanks,
    1. GSM.zip
  • #2465
    Peter Koncz
    BTW, I have also created 2D symbols for the user to comply with Hong Kong standards.
    Can you help me how to add a fill to the rectangle symbol?
    1. GSM-2.zip
