Home › Forums › Problems and solutions in GDL › Documentation elements, text handling › Custom door marker
This topic contains 8 replies, has 3 voices, and was last updated by Izabela Str 12 months ago.
February 16, 2018 at 16:06 #3812
Can someone tell me if it’s possible to edit somehow the script of door marker to change the parameters which are responsible for the viewed dimensions? Is it possible to view with door marker the structure wall-hole dimensions? I mean the construction one. Now it displays the dimensions from finished floor not the structure. I’m asking about this because in the schedule when I add for example ‘Nominal W/D Opening Height on the Reveal Side’ or ‘Nominal W/D Opening Width on the Reveal Side’, displays the values which I need. Is it possible to modify somehow the script to add this dimensions?
Any clues?
Cheers,
February 16, 2018 at 19:49 #3813
You’ll have to be more specific in your request, as the D Marker 21 already does this. When using, say, “Door 21,” the A & B values represent the wallhole dimensions, with the frame, leaf dimensions, casings etc being inside that. You can set offset and door undercut values already, and dimension the sill.
Is this not what you were after?
www.brucepwalker.com
NVIDIA GeForce GTX 1060 8Mb -
February 19, 2018 at 08:49 #3815
To be more precisely I’ve added below few preent screens.
February 19, 2018 at 08:50 #3818
the settings of doors
February 19, 2018 at 08:51 #3819
the setting of the door one more time
February 19, 2018 at 12:59 #3823
Hi Izabela,
yes, you can use use
ac_wido_oversize_b
parameter. The D Marker 21 uses this withac_wido_subfl_thickness
to display the sill height.Here is a listing of all available parameters for markers:
February 19, 2018 at 14:33 #3824
Hi Péter,
that you for your answer.
I have one more question. Is this the same with ‘Door Marker 21’?-
February 20, 2018 at 08:50 #3826
I don’t know about Door Marker 21, Door Stamp 21 does this too.
February 20, 2018 at 08:53 #3827
Thanks.
