Home › Forums › Problems and solutions in GDL › 3D modelling › DESCTIVATING A CUTPLANE FROM 2D SCRIPT or similar method
- This topic has 10 replies, 3 voices, and was last updated 6 years, 9 months ago by
Nader Belal.
February 26, 2019 at 23:24 #4532
Nader Belal
ParticipantHi there,
I´ve created a complex object that is being controlled by a myriad of parameters and conditions (basically a sandwich panel with an arbitrary number of holes and shapes with the ability to trim the corners at an angle defined by the user, and the ability to receive gabled roof; all at the desired LOD) . . . so to create an accurate plan view I have used CUTPLANE in the “3D script” and used PROJECT2{4} in the “2D script”
My problem have started when I wanted to include an elevation view on plan (similar to ArchiCAD’s wall accesory object for wood frame walls) since I have use this code:
Project2 4, 270, 2As expected, the views I got is that of the panel with the part above the CUTPLANE trimmed.
And I can not stop the use of CUTPLANE predefined in the “3D script” since that PROJECT2{4} will not show correctly the different types of voids applied to the panel (at least the different skins and building materials applied to them in the “3D script“)
So I need this, either:
a) A condition that can deactivates the CUTPLANE in the “3D script” when the user asks for an elevation view on Plan.
b) Or another way to create the cut plane view that doesn’t scripting the view (due to the associated difficulty) and doesn’t need a cut plane.
c) or any other method capable of achieving the desired result.This issue have been also been discussed in this thread (https://archicad-talk.graphisoft.com/viewtopic.php?f=6&t=66286), but not the needed results until the time I have written this thread in the GDL center.
Worth to mention that other tried issues where:
a) A condition in 2D to activate/deactivate the CUTPLANE in the “3D script“.
b) A routine that in the “3D script” one with the CUTPLANE activated, and another deactivated.
c) Passing the CUTPLANE and PROJECT2{4} ****** to “Master Script”
d) Passing the 3D modelling procedures of the object to the Master Script******.******
When I passed the CUTPLANE and PROJECT2{4} to the “3D script“, the ENDPLANE caused PROJECT2{4} to give unexpected results, please see the thread above for more info. -
February 27, 2019 at 04:34 #4533
ParticipantSo I need this, either:
a) A condition that can deactivates the CUTPLANE in the “3D script” when the user asks for an elevation view on Plan.I assume the showing of the elevation in plan view is a parameter option.
I would then do this.if elevation_in_plan = 1 and GLOB_VIEW_TYPE = 2 then !Plan view !!!!do nothing else CUTPLANE 0, cutplane_height endif ... 3D model script ... if elevation_in_plan = 1 and GLOB_VIEW_TYPE = 2 then !Plan view !!!!do nothing else CUTEND endifI am sure it could be scripted differently.
February 27, 2019 at 10:52 #4537
Nader Belal
a) A condition that can deactivates the CUTPLANE in the “3D script” when the user asks for an elevation view on Plan.Sorry my bad …
I needed to deactivate the CUTPLANE in the “3D Script” if the user need an elevation view on the plan, but on the same time mantaining the cut plan view of the object.
I have already solved this issue in this post https://archicad-talk.graphisoft.com/viewtopic.php?p=294857#p294857, and I recognise that it’s not the best nor the more efficent way to do it, but I would gladly like to hear your opinion.
February 27, 2019 at 11:07 #4538
KeymasterHi,
in 3D script, GLOB_VIEW_TYPE is 2 when the 3D script is run for project2. That’s what Barry’s example does, too.
February 27, 2019 at 20:12 #4545
Nader Belal
ParticipantI will try make myself clear again.
I need to create a cut plan view in plan AND an elevation view on plan at the same time.
My problem is that with a CUTPLANE active in the “3D Script” will generate an elevation view on plan with it’s upper part is cut.
And if I deactivate CUTPLANE in the “3D Script” the section plan view will not show correctly.I need both right at the same time … How ?
February 28, 2019 at 02:41 #4549
ParticipantIf you can get the correct views with the cutting planes in the PROJECT2 command then in the 2D script you use it twice.
PROJECT2 - top view with desired cutting planes if show_elevation = 1 then ADD2 x,y PROJECT2 - side view with desired cutting planes DEL 1 endifIf you need to use an actual CUTPLANE in the 3D script to get the projection you want then use the if/then command to control the CUTPLANE and CUTEND as I mensiomed before (but you won’t need the GLOB_VIEW_TYPE = 2).
The thing is you will need to turn off the CUTPLANE for one of the passes.
Again this may not be the best scripting but I would do this.show_elevation_orig = show_elevation show_elevation = 0 !!!!temporarily turn of show in elevation mode PROJECT2 - top view with or without built in cutting planes show_elevation = show_elevation_orig !!!!set elevation mode back to original if show_elevation = 1 then ADD2 x,y PROJECT2 - side view with or without built in cutting planes DEL 1 endifBarry.
February 28, 2019 at 22:49 #4556
Nader Belal
ParticipantOk I will try that.
March 1, 2019 at 09:16 #4560
KeymasterParameters and variables set in the 2D script doesn’t get through via project2 to the 3D script.
You can define cutplanes in the 2D script using the PROJECT2{4} command. Unfortunately it has a bug, so it doesn’t show correct cut fills from the 3D model. You can set a cut fill override if you need only one cut fill.
You can also use PROJECT2{3} with PARAMETERS, setting a hidden parameter whether you need the cutplane or not.
March 1, 2019 at 21:45 #4562
Nader Belal
Participant@Péter Baksa
Are you telling me that in my case, the best solution (actually second best) available for me now, is to make a 2nd copy of the object in the 3D script, and use the same project2{what ever version} to get the cut plan view and and elevation view at the same time ???!!!!
March 4, 2019 at 08:12 #4566
KeymasterHi Nader,
yes, that could also work with the simple project2. Or you could project2{3} … parameters … twice.
March 4, 2019 at 12:20 #4569
Nader Belal
ParticipantThank you
