Home › Forums › Problems and solutions in GDL › Object design › Gradient fill
Tagged: Fills, distortion, fill, poly2_b, gradient fill
- This topic has 5 replies, 3 voices, and was last updated 7 years, 7 months ago by
John Hyland.
February 14, 2019 at 22:25 #4500
John Hyland
ParticipantI notice the manual suggests gradient fills are possible [DEFINE LINEAR_GRADIENT_FILL]. But there are no explainations or examples how to implement. If any one has a simple example or tutorial it would be great.
John -
February 21, 2019 at 10:07 #4511
KeymasterHi John,
The definition part is simple, the trick is in setting up the fill distortion. The transformation matrix used by poly2_b{3} is interpreted differently for gradient fills: the end coordinates of the axes should be given relative to the object origin, not the fill origin.
DEFINE LINEAR_GRADIENT_FILL "gradfill" fill "gradfill" ! fill origin OriginX = 0.5 OriginY = 0.5 ! pattern angle patternAngle = 30 ! size patternSize = 0.5 ! length of gradient from fill pen to background pen poly2_b{3} 4, ! # of edges 1 + 2 + 4 + 8, ! contour + fill + close polygon + local fill orientation 1, 0, ! fill pen, fill background pen OriginX, OriginY, ! fill origin OriginX + patternSize * cos(patternAngle), OriginX - patternSize * sin(patternAngle), ! X of pattern axis X, X of pattern axis Y OriginY + patternSize * sin(patternAngle), OriginY + patternSize * cos(patternAngle), ! Y of pattern axis X, Y of pattern axis Y 0, 0, 1, ! vertices 0, 1, 1, 1, 1, 1, 1, 0, 1Péter Baksa
February 22, 2019 at 03:26 #4512
ParticipantA few questions just for my understanding if I may.
1.) So there is no need to DEFINE the fill if you already have the gradient fill as an attribute?
Just SET FILL “Linear Gradient Fill”.After all you are not really defining a pattern for the fill.
Every gradient fill you define is exactly the same as the others, just with a different name (and attribute number).
It is all about using the correct options in the POLY2_B[3] command and setting the required pen colours.2.) Why can we not see the gradient and radial fills when a fill parameter is created in the parameter list?
But we can ‘SET FILL’ using those attributes by name in the script.
It would be nice to be able to choose solid, vectorial, symbolic, image and gradient fills from a parameter.3.)Is there a tricky way to set up graphical hotspots to adjust the settings?
I can create hotspots to move the fill origin.unID=1 !Stretchy x HOTSPOT2 0, OriginY, unID, OriginX, 1+128 : unID=unID+1 !base HOTSPOT2 -1, OriginY, unID, OriginX, 3 : unID=unID+1 !reference HOTSPOT2 OriginX, OriginY, unID, OriginX, 2 : unID=unID+1 !moveable !Stretchy y HOTSPOT2 OriginX, 0, unID, OriginY, 1+128 : unID=unID+1 !base HOTSPOT2 OriginX, -1, unID, OriginY, 3 : unID=unID+1 !reference HOTSPOT2 OriginX, OriginY, unID, OriginY, 2 : unID=unID+1 !moveableAnd I can add a hotspot to rotate the fill.
!angle stretchy hotspot HOTSPOT2 OriginX,OriginY,unID,patternAngle,6 : unID=unID+1 !centre HOTSPOT2 OriginX+(patternSize),OriginY,unID,patternAngle,4+128 : unID=unID+1 !base HOTSPOT2 OriginX+COS(patternAngle-symb_rotangle)*(patternSize),OriginY+SIN(patternAngle-symb_rotangle)*(patternSize),unID,patternAngle,5 : unID=unID+1 !stretchy hotspotBut I can not make that rotational hotspot also stretch the pattern length.
If I comment out the above rotation hotspot and add this, I can stretch the pattern length.ADD2 OriginX, OriginY ROT2 patternAngle !Stretchy gradientlength HOTSPOT2 0, 0, unID, patternSize, 1+128 : unID=unID+1 !base HOTSPOT2 0-1, 0, unID, patternSize, 3 : unID=unID+1 !reference HOTSPOT2 0+patternSize, 0, unID, patternSize, 2 : unID=unID+1 !moveable DEL 1 DEL 1I guess what I am asking here, is there a way to combine the rotation hotspot with the pattern length?
So we can have a stretchy rotation.
Or will they have to be two separate hotspots?Barry.
February 22, 2019 at 09:32 #4513
KeymasterHi Barry,
1, as long as you know the name of the fill, no need to define it. But the default name is localized.
2, I agree, it would be nice. But you would still have to do extra work in GDL to use them.
3, I didn’t try if a rotational and a moveable hotspot can be linked like two moveable hotspots can.
You could also try using a moveable hotspot for the origin, one moveable for the end of the radius, and doing the computations in the background with linked hidden parameters, showing angle/r instead of x/y in the tracker.Péter Baksa
February 22, 2019 at 09:54 #4514
ParticipantThanks Peter.
I don’t think a rotational and moveable hotspot can be linked which is why I was asking.
I will give your hidden calculations a go – I think that might be the only way.Usually with something like this I would have one hotspot for the origin x & y, another for the length and a rotation one at half the length.
February 24, 2019 at 07:01 #4526
John Hyland
ParticipantThanks Péter
and Barry keep us posted on progress.
