Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › Interface image clarity
- This topic has 8 replies, 3 voices, and was last updated 4 years, 11 months ago by
Bruce Walker.
March 15, 2016 at 21:22 #2340
Bruce Walker
ParticipantI’ve created images to use in the interface I’m writing, but for some reason the edges are all jagged when I bring them into ArchiCAD. They are nice and smooth when I view them in Windows (or import them into, say, Excel). What is the trick?
www.brucepwalker.com
NVIDIA GeForce GTX 1060 8Mb -
March 15, 2016 at 21:41 #2342
ParticipantI think, the size in pixel of the image must be the same in the User Interface as in the original image file. You can measure this with a screen capture application. If it is to small, you must widen the Infields.
MAC OSx 10.14 -
March 22, 2016 at 02:14 #2347
Bruce Walker
ParticipantThanks Joachim. I have tried adjusting the image size in the user interface, but this has no real effect on the pixelation.
March 23, 2016 at 18:48 #2349
ParticipantPlease post your Script for the UI_INFIELD and the original size of the image.
MAC OSx 10.14 -
March 23, 2016 at 22:06 #2350
Bruce Walker
ParticipantThis is the code:
UI_INFIELD{3} “sentry_type”, ui_x1, ui_y, 270, ui_selection_h,
2, “Sayfa SENTRY Guardrail”, 2, 1,
144, 100, 136, 80,
sentry_concrete, type_sentry[sentry_concrete], type_sentry[sentry_concrete],
sentry_metal, type_sentry[sentry_metal], type_sentry[sentry_metal]And the image referred is attached.
March 24, 2016 at 09:18 #2352
ParticipantYour Pictures size value of 136,80 should be half the size of the picture, as I think.
If I do this, the captured screenshot of the UI matches with the picture, in your script not.ui_x1 = 1 ui_y = 1 ui_selection_h = 100 UI_INFIELD{3} "sentry_type", ui_x1, ui_y, 160, ui_selection_h, 2, "Sayfa-SENTRY-Guardrail", 2, 1, 160, 100, 144, 80, sentry_concrete, type_sentry[sentry_concrete], type_sentry[sentry_concrete], sentry_metal, type_sentry[sentry_metal], type_sentry[sentry_metal]
Although the edges are still jagged a bit, they are absolutely identical to the picture you loaded up.
MAC OSx 10.14 -
March 28, 2016 at 22:07 #2353
Bruce Walker
ParticipantThanks Joachim. I’m clearly getting something wrong with my images. I can’t figure out how to get them nice and sharp – as is the case in, for example, “Hood 19”
NVIDIA GeForce GTX 1060 8Mb-
March 29, 2016 at 16:30 #2354
KeymasterJoachim is right about picture size: the displayed size should match the original width and height (this case, since it’s a 2 picture matrix, half size should be appropriate) most of the time. The original picture looks jagged if I just open it in Finder Preview on Mac. It’s more of a picture editing question than GDL, I think. We got the Hoods right in the Library, but if you take a closer look to the door handle popup images, you can see some jagged lines there as well (they are not prefect at all). You may try to save a double sized original picture with better resolution (so it has smaller visible pixelation at the slanted edges), and scale it to half size in the command’s image_x, image_y parameters. That may help a bit. Using .png format is recommended as well instead of .tif.
March 29, 2016 at 21:30 #2355
Bruce Walker
ParticipantThanks Dominika. I tried your suggestion of both png & making image twice as large. Neither made an improvement.
However, if, in your experience, this is the appearance that can be expected, then I am satisfied. I was just comparing my interface with GS’ interfaces, and mine seemed to be lacking, and I thought perhaps there was a trick I was missing.
Thanks all for your help.
