ISSUE: UI DIALOGUE USER INTERFASE
Home Forums Problems and solutions in GDL Graphical UI and parameters list ISSUE: UI DIALOGUE USER INTERFASE
This topic contains 1 reply, has 2 voices, and was last updated by  Piotr Dobrowolski 1 month, 2 weeks ago.
  • #18224
    Nader Belal
    Dear Graphisoft,
    I would like to point at two thinks:
    1. In ArchiCAD GDL manual, it does say anything about how it can become a problematic issue working with .PNG or .Tif files type directly on the user interface dialogue box (i.e.: transparency only works in any other case, & I don’t know if that was also true for .SVG files)
    2. I think you should work of this issue
    Best regards,
    Nader
  • #18506
    Piotr Dobrowolski
    SVG files are not used directly. They have to be converted to bitmap format – howto is put in my tread next to Yours.
    PNG and TIFF files can have the transparent bit, so it can be used in AC UI, while JPG format do not have such feature, so the transparency will not work on it.
    Piotr
