MEP Connections
Home Forums General discussions MEP Connections
This topic contains 2 replies, has 3 voices, and was last updated by  Vasyl simple_Vasyl 3 months ago.
  • #18072
    Dániel Vida
    I have a C++ addon which places library elements especially mep element, like straight pipe bend pipe, Y, T connections etc… But i have a problem with the connections. If i place a straight pipe from the original mep library, i cannot create start a pipe/ take off from that element. So i assume that there are some parameters which is not configured properly… So my question is that which parameters should i set if i place a straight pipe, or any other object whoich uses gs_Connections. i found the tips and tricks about creating library elements with mep connections, ut it doesn’t help me to place them with addon.
  • #18142
    Hi Dániel,
    it’s not possible to create MEP connections from another add-on. You can only write GDL objects that must be placed manually through the MEP add-on.
  • #18283
    Vasyl simple_Vasyl
    Never mind, I found I can’t upload “.gsm” file
