Pen_​​of_​​RGB
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 3 years, 6 months ago.
  • #2925
    Pen_of_RGB only works for me with numbers, not with variables. Is there a trick?
    This works:
    _stift = REQ(“Pen_of_RGB 0 0 0.7”)
    xx = REQUEST (“PEN_OF_RGB”, “0 0 0.7”, _stift)
    This does not work:
    _blue = 0.7
    _stift = REQ(“Pen_of_RGB 0 0 _blue”)
    xx = REQUEST (“PEN_OF_RGB”, “0 0 _blue”, _stift)
    MAC OSx 10.12
  • #2926
    Pen of rgb request needs a string with 3 numbers in it – so there is no trick. If you need to use variables with that, then you need to create your own “r g b” string with the str function first, and then use it with the request.
