Return parameters without a parameter
Home Forums Problems and solutions in GDL Parameter connections Return parameters without a parameter
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 1 year, 11 months ago.
  • #3790
    Bruce Walker
    In looking through the scripts for the Built-In Section Marker, I found that one script is returning values to another without any corresponding parameters (if you want to look, it’s the values ‘t1’ & ‘t2’ in the macro “Marker Link Parameters” being returned to “Section-Elevation Marker Macro.”)
    I tried to mimic this behaviour in a couple of my scripts to avoid creating unnecessary parameters, but it doesn’t work. What’s the trick?
    www.brucepwalker.com
    NVIDIA GeForce GTX 1060 8Mb
  • #3791
    The returned parameters is just a “simple value list” in the specified order – it is not really “parameters”, just variables in the scripts.
    You need to declare the list of values to be returned at the end of the called macro’s script, like this:
    end value1, value2, value3
    Then in the caller object, you need to specify the variables to where you want to fill in these values:
    call “samplemacro” parameters …..
    returned_parameters variable_receives_value1, variable_receives_value2, variable_receives_value3
    I hope it helps, if not, please upload a sample which you can’t solve. (Upload in zip please, as gsm files are forbidden by the hosting service provider of this site.)
