Solid ops and subroutines
Home › Forums › Problems and solutions in GDL › 3D modelling › Solid ops and subroutines
Viewing 3 reply threads
    • #3709
      I’m getting inconsistent results depending on whether ADDGROUP is used in a subroutine or in the main script. Example:
      Version 1, add groups in main script, works:
      GROUP ‘things’
      	etc
      ENDGROUP
      GOSUB 100
      foobar_ = ADDGROUP(‘foo’, ’bar’) !! NB, in main
      final_ = SUBGROUP(foobar_, ‘things’) !! this works
      PLACEGROUP final_
      END
      100:
      GROUP ‘foo’
      	stuff
      ENDGROUP
      GROUP ‘bar’
      	more stuff
      ENDGROUP
      RETURN
      Version 2, add groups in subroutine, doesn’t work:
      GROUP ‘things’
      	etc
      ENDGROUP
      GOSUB 100
      final_ = SUBGROUP(foobar_, ‘things’) !! this gives error that foobar_ isn’t group name
      PLACEGROUP final_
      END
      100:
      GROUP ‘foo’
      	stuff
      ENDGROUP
      GROUP ‘bar’
      	more stuff
      ENDGROUP
      foobar_ = ADDGROUP(‘foo’, ’bar’) !! NB, in subroutine
      RETURN
    • #3710
      Wow that formatting looks great. Never mind. If you want to use an ADDGROUP result in a subsequent SUBGROUP operation, you can’t do the ADDGROUP in a subroutine. It would be nice to know why.
    • #3711
      Hi James,
      the GDL interpreter runs some checks before executing the script. This check is done line-by line, not in execution order. In version 2 when it first comes to foobar_, that is an uninitialized variable, but it would expect string or group type. Sadly we can’t easily initialize a variable to be group type.
      A solution:
      – move the subgroup and placegroup commands to another subroutine, placed after subroutine 100
      Less elegant solution if the above doesn’t work for your code structure:
      – initialize group type variable: create an empty group and add it to itself, creating a group type variable
      group “dummy”
      endgroup
      foobar_ = ADDGROUP(“dummy”, “dummy”)
      killgroup “dummy”
      GOSUB 100
    • #4782
      Nader Belal
      My 2 cents,
      This group structure is neither nice, nor clean, and it may cause a lot of confusion when the times arrives for code maintenance, all because the followed structure.
      My solution
      gosub 100
      bla ... bla ... bla
      end
      100:
      GROUP ‘things’
      	etc
      ENDGROUP
      if something then
      	GROUP ‘foo’
      		etc
      	ENDGROUP
      	GROUP ‘bar’
      		etc
      	ENDGROUP
      end
      ! -- Group placements ---------------
      if nothing then
      	placegroup ‘things’
      	killgroup ‘things’
      end
      if something then
      	placegroup subgroup (addgroup (‘foo’, ’bar’), ‘things’)
      	killgroup ‘things’
      	killgroup ‘foo’
      	killgroup ‘bar’
      end
      return
  • The forum ‘3D modelling’ is closed to new topics and replies.
