text tied to A/B/ZZYZX parameters
Home Forums Problems and solutions in GDL Documentation elements, text handling text tied to A/B/ZZYZX parameters
This topic contains 1 reply, has 2 voices, and was last updated by  Gergely Fehér 3 years, 2 months ago.
  • #2916
    Patrick May
    I have a text box that calls to Parameters A & B for associated lengths in a stamp/label object. The problem is, the object uses metric conversions of length A/B, rather than tying to any kind of local or global parameters for imperial feet and inches. Is there a way to tie TEXT2 to DEFINE STYLE and associate with my project’s working units?
  • #2919
    You can request the formatting string to the project’s working units, for example REQUEST ("Linear_dimension", "", format_string) Please check the available requests in the documentation. After you have the formatter string, you need to create a string from the specific parameters value, with the STR or STR{2} functions, you’ll find the docs with sample on this page.
