Home › Forums › General discussions › Uploading to BIM Components
- This topic has 11 replies, 6 voices, and was last updated 6 years, 6 months ago by nicola gardoni.
October 14, 2015 at 14:28 #1747shaun coomberParticipant
Hi
I’ve recently decided to upload some GDL content to bimcomponents.com, and have a couple of questions regarding the checking process.
Firstly, regarding global parameters and requests. I know that these are now restricted and should not be returned to the parameters list.
However, I have used a couple of requests in the master script (‘FULL_ID_OF_PARENT’ and ‘ID_OF_MAIN’) so that these can be used throughout the object without storing these as parameters. This flags up as an error in the checking process, because the requests are done in the master script and therefore follows through into the parameter script.
To (hopefully) avoid the problem I have used GLOB_SCRIPT_TYPE <> 5 in the master script.
Could you please clarify this?
I also get two “Uninitialized variable” reports. These do not flag up as an error in the object when I check script, and the report does not say which variables are at fault. Will this stop the file from uploading? Is the only way to find these to convert back to XML and refer to the line number?
On a side note, when uploading to bim components, the URL to the FAQ is broken (https://archicadwiki.com/BIMcomponents/FAQ).
October 14, 2015 at 16:59 #1748Gergely FehérKeymaster
Shaun,
Quick answers:
1. GLOB_SCRIPT_TYPE is ok in the master script.
2. Line numbers: check script should show all errors and warnings. If you send me a file, I can check it, if there is a bug…
3. FAQ: I clicked on your link, and it is working normally. Maybe it could be a temporary server problem…Gergely Fehér
October 19, 2015 at 06:49 #1756Ben CohenParticipant
This is very interesting. So if we use “if GLOB_SCRIPT_TYPE <> 5 then” in the master script to prevent the code from running in the parameter script, we will not receive an error?
October 19, 2015 at 13:09 #1760Gergely FehérKeymaster
Ben, it is the purpose of GLOB_SCRIPT_TYPE: it enables you to write script parts to the master, which will be used in only selected scripts.
February 10, 2016 at 10:51 #2215Heimo MooslechnerParticipant
There are several of my last uploaded GDLs on bimcomponents, which got no downladbutton on the site! I have written to the bimcomponents-Support month ago but there is no respond and no new downloadbutton on the elements-sites.
One of several examples there:
https://bimcomponents.com/GSM/Details/21360
Teacher in HTL-Salzburg
AC5-19, Win and Mac
GDL hobby developer -
February 11, 2016 at 02:14 #2239Barry KellyParticipant
There is no “Download” button as such but there is the ‘drag & drop’ arrow that works.
Thing is the object is imported with no name – i.e. it is called “.gsm”.
So it doesn’t show up as a window object.
It can be opened and renamed though and then can be used as a window object.Barry.
February 11, 2016 at 14:02 #2249Heimo MooslechnerParticipant
In the meantime someone made it! Thank You!
AC5-19, Win and Mac
February 29, 2016 at 15:29 #2312Gergely FehérKeymaster
Now we corrected the empty name error too, so you can drag these solo objects to ARCHICAD, and do not need to rename them. Thanks for your patience, and thanks for the reports.
September 21, 2017 at 16:51 #3556nicola gardoniParticipant
Hallo
3 weeks ago I’ve uploaded on Bimcomponents some new GDL lighting fixtures , how much does it take to be available to download?Best Regards
Nicola-
September 27, 2017 at 11:44 #3557Gergely FehérKeymaster
Nicola,
We checked your uploads, and seems that all your objects failed the automatic tests – normally you should receive a mail about that. We checked the mail logs too, and we saw that there were problems with mail sending in a few days period – but that seems to be fixed for now. Please try to upload your libs again, and if you have any problems again send us a mail with the problematic objects.
Sorry for the inconvenience.
September 27, 2017 at 13:51 #3558nicola gardoniParticipant
Dear Gergely
many thanks for your infos, I’ve just upload again the models.
I will wail the email. -
September 29, 2017 at 15:21 #3559nicola gardoniParticipant
Dear Gergely
many thanks for your email.
Please check your servers because I didn’t received the email report about the failed uploads.
Can you tell me what is the issues about on our models?Thanks
Nicola
