Home › Forums › Problems and solutions in GDL › Doors and windows › WALL_SKINS_PARAMS and Building_Material_info
- This topic has 7 replies, 4 voices, and was last updated 7 years, 11 months ago by
James Hoth.
May 5, 2016 at 12:48 #2443
ParticipantI try to read the surface material from a composite wall for a window, but it seems that the Request “Building_Material_info” does not work quite well.
The Material is shown in 3D Window of GDL-Editor correctly as well as in the Lib-Part-Preview, but not in the 3D Window (AC 18 and 19). See attached Scrennshot.My script is as following:
DIM wand_fill[], wand_fill_pen[], wand_back_pen[], wand_cont_pen[], wand_thck[], wand_cont_pen_unten[], wand_mat[], mat_index[] FOR ii=1 TO ski_no wand_fill[ii] = WALL_SKINS_PARAMS[ii][1] wand_fill_pen[ii] = WALL_SKINS_PARAMS[ii][4] wand_back_pen[ii] = WALL_SKINS_PARAMS[ii][5] wand_cont_pen[ii] = WALL_SKINS_PARAMS[ii][9] wand_cont_pen_unten[ii] = WALL_SKINS_PARAMS[ii][7] wand_thck[ii] = WALL_SKINS_PARAMS[ii][2] wand_mat[ii] = WALL_SKINS_BMAT_NAMES[ii][1] x = REQUEST{2} ("Building_Material_info", wand_mat[ii], "gs_bmat_surface", mat_index[ii]) NEXT ii MATERIAL IND(MATERIAL, mat_index[1])Attachments:
MAC OSx 10.14 -
May 6, 2016 at 07:20 #2445
KeymasterHow do you get the ski_no value?
May 6, 2016 at 16:39 #2446
Participantski_no = WALL_SKINS_NUMBER
And the REQUEST was not correctly copied (Array-Index) was missing:
This seems to be prohibited by the forum software (square brackets where left out)GDL Object Developer
MAC OSx 10.14 -
May 9, 2016 at 08:00 #2449
KeymasterI corrected the codes: please use ohter variables than i for the loops in this forum. “i” in square brackets is for italic in BBCode, that’s why it is eliminated from codes.
May 20, 2016 at 13:08 #2478
ParticipantGergely, did you find out anything about this issue?
MAC OSx 10.14 -
May 24, 2016 at 13:22 #2481
KeymasterWALL_SKINS_BMAT_NAMES did not work in 3D views in AC18&19. It will be corrected for AC20.
May 29, 2018 at 01:01 #4097
Kristian Bursell
ParticipantHi Gergely (and Joachim),
I thought i would add this question here as it is related.
I have a problem where the WALL_SKINS_PARAMS is not working in the 3D script but works in the 2D script.
I am creating plaster returns for my windows and the 2D works fine but the 3D is acting as if the wall is a single skin saying the index is greater than the array dimension.SCRIPT (identical in 2D and 3D)
if WALL_SKINS_NUMBER > 1 then
!!——————————————-INTERNAL
SKINFillInt = “”
SKINThickInt = .010
SKINPenInt = 1
SKINPenFillInt = 1
SKINPenBGInt = 1
if GLOB_CONTEXT # 5 then
SKINFillInt = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][1]
SKINThickInt = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][2]
SKINPenInt = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][9]
SKINPenFillInt = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][4]
SKINPenBGInt = WALL_SKINS_PARAMS[WALL_SKINS_NUMBER][5]
material WALL_MAT_ACADSWIFT
Australia -
September 20, 2018 at 23:00 #4270
James Hoth
ParticipantI have a related issue, I assume that the limitation or the wall_skins_number is only the skins that are being cut in the 2d plane? or is there a way to get the info for all the skins cut and not?
AC 22, Twinmotion 2019, Macbook Pro 2017 w/ 3.1ghz kabylake, radeon 560 pro, radeon rx vega 54 egpu, Xkeys 68 jog & shuffle, wacom intuos pro m, better touch tools
