Home › Forums › Problems and solutions in GDL › Lists and schedules › Zone Stamp not outputting to schedule
- This topic has 9 replies, 4 voices, and was last updated 9 years, 11 months ago by
Gergely Fehér.
March 1, 2016 at 18:43 #2315
Derek Jackson
ParticipantHi,
I’m editing the basic Zone Stamp to make quite a few changes, and all works perfectly apart from the scheduling, which fails to output my new variables.I have a series of lines in the 2D script that convert the basic measured and calculated areas to acres, ft2, hectares, etc.
area_m2 = str (area_form, Temp_GrossArea) area_ft2 = str (area_form, (Temp_GrossArea*10.7639)) area_acre = str (area_form, (Temp_GrossArea*0.00024710538146)) area_hect = str (area_form, (Temp_GrossArea*0.0001)) calc_acre = str (area_form, (Temp_CalcArea*0.00024710538146)) calc_hect = str (area_form, (Temp_CalcArea*0.0001))I’ve then set up a series of holder parameters (as ‘Text’) in the main parameter list – so ‘area_hect’, ‘calc_acre’, etc.
Finally, I have the lines:
parameters area_m2 = area_m2 parameters area_ft2 = area_ft2 parameters area_acre = area_acre parameters area_hect = area_hect parameters calc_acre = calc_acre parameters calc_hect = calc_hectin my Master script in the hope that it will update these variables on the fly for scheduling.
However, all scheduling just shows a blank entry for each of the parameters. I’m stumped as to what I’m doing wrong – can anyone help?
Thanks,
Derek
March 2, 2016 at 02:26 #2317
ParticipantTry doing the conversions in the master script rather than the 2D script.
Anything you calculate in the 2D script can only be used in the 2D script and the values can’t be used to be sent back as parameters.Barry.
March 2, 2016 at 11:18 #2319
Derek Jackson
ParticipantThanks Barry, that’s a good start – I’m now halfway there!
When I first add a new zone to the plan, the parameters output to the schedule correctly. However, if I then edit the zone footprint, the schedule doesn’t update, although it happily reads in a second new zone.
However, if I edit the zone footprint, then open the Zone Settings Dialogue and close it again, the schedule then updates – it’s like the schedule only registers that the parameters have changed when the Settings Dialogue is opened (or is this the only time the
parameters area_m2 = area_m2line is called?)For clarity, the relevant code in my Master script is:
! output string = 'A:' + output string + written unit area_m2 = AreaM2Text + area_m2 + ' sq m' area_ft2 = AreaFt2Text + area_ft2 + ' sq ft' area_acre = AcreText + area_acre + ' ac' area_hect = HectText + area_hect + ' ha' calc_acre = CalcAcText + calc_acre + ' ac' calc_hect = CalcHaText + calc_hect + ' ha' ! Update for scheduling parameters num_area_m2 = num_area_m2 parameters cat_title = cat_title parameters area_m2 = area_m2 parameters area_ft2 = area_ft2 parameters area_acre = area_acre parameters area_hect = area_hect parameters calc_acre = calc_acre parameters calc_hect = calc_hectAny thoughts on what I need to do? It feels like it’s really close now!
Thanks,
Derek
March 3, 2016 at 18:18 #2327
KeymasterDerek,
your parameters are not refreshed, until paramscript is not running. How did you change your zones? With the update zone function, or editing the hotspots on their contour or editing them with marquee?Gergely Fehér
March 3, 2016 at 18:56 #2328
ParticipantGergely,
a question about the running of the Parameters commands:
They are placed in the Master Script.
Does your answer mean, that the Parameters command is only executed,
if a parameter is changed, which applies to the Parameter Script as whole, although the command is placed in the Master Script?
As the Master Script is executed more often, does it skip the Lines with the Parameters Commands?GDL Object Developer
MAC OSx 10.14-
March 3, 2016 at 19:34 #2329
KeymasterJoachim,
Parameters commands only executed when the master script runs as a parameter script – before then paramscript itself. In all other contexts paramscript commands like parameters or values are skipped. (Just a note: in a teamwork situation, when a floorplan is drawn and master script and 2d script runs, you don’t have the right to change the object parameters. To be able to change the parameter list of an element, you need to reserve that first.)Gergely Fehér
March 3, 2016 at 22:00 #2331
Derek Jackson
ParticipantThanks Gergely, by updating I mean simply editing the shape of the zone contour by moving the hotspots. So does this not update the parameters? If not, how can I force an update?
March 4, 2016 at 13:51 #2332
KeymasterDerek,
I made a simple test object, a new zone stamp. I added a new parameter “myArea” (a realnum) to the paramlist, andtext2 0, 0, myAreato the 2d script andparameters myArea = ROOM_AREAto the parameter script. With this I tested a placed zone, and if I moved any of the zone’s hotspots the area text is changed, so paramscript has run. If I edited the zone with a marquee, then the text has not changed – so in this situatuion the paramscript did not run. This second case with the marquee is a known issue, we are working on a solution for the next main version for that.
You can force the parameter script run with opening it’s settings dialog and closing it with “Ok”.
If you have any other workflows which changes the zone and does not change the parameters, then please report it to me. Thanks.Gergely Fehér
March 7, 2016 at 17:28 #2333
Derek Jackson
ParticipantThanks Gergely.
I haven’t looked at marquee editing or any other methods, so this just refers to moving hotspots.
I wonder if the error may be that I’ve converted the values to strings, and these don’t directly update, as they’re only translated when the settings dialogue is opened.
However, when I tried some mathematical calculations on the ROOM_AREA parameter (eg calculating acres via
area_acre2 = (ROOM_AREA*0.00024710538146), it throws up an error sayingOperator can be used only for numeric type operands
(area_acre2 is an undefined parameter type in the example above)
Any help on how I can get round this?
Thanks,
Derek
March 7, 2016 at 19:18 #2334
KeymasterDerek,
Let me check that object, please send it to me to gdlcenter@graphisoft.comGergely Fehér
- The forum ‘Lists and schedules’ is closed to new topics and replies.
