Barry KellyParticipant
Laura,
Do you mean that the arrow head moves when you stretch the text hotspot?
If so that is happening to me using your object in 18, 19 and 20 – they are all working the same.
I don’t see any problems with GLOB or REQUEST in the master/parameter scripts.
Those you have used are allowed (although judging from my other posts I am no expert in this field!).It seems to me the problem is with the 2D hotspots in that the one for the text position is altering the value for the arrow head.
I haven’t got time to dig into it in detail though just at the moment but hope this helps.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI meant to say ‘GLOB_CONTEXT = 1’ not 5…
But I guess I am desperately after a way to have a parameter not be set while in the library part editor – i.e. the old ‘GLOB_CONTEXT = 1’ which now of course doesn’t work.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThanks Gergely.
I think it is finally sinking in that GLOB_VIEW_TYPE will have a default of ‘2’ which is why the ‘if GLOB_VIEW_TYPE = 2 then …’ set ‘firstRun = 1’ but the ‘if GLOB_VIEW_TYPE = 3 then …’ doesn’t (because it actually equals’2′ not 3).I think that is what keeps confusing me – not that the command no longer works but that it has a default value that can make it appear that it is working in some circumstances.
But I guess I am desperately after a way to have a parameter not be set while in the library part editor – i.e. the old ‘GLOB_CONTEXT = 5’ which now of course doesn’t work.
So I am looking for anything that will work and am clutching at straws.
I thought I might be on a winner her but no I wasn’t.There is a solution for me and it requires migration of the objects.
It works fine, just more involved to get it working.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantThis has just cropped up again in ArchicadTalk … https://archicad-talk.graphisoft.com/viewtopic.php?t=53078
I was having a bit of a play again and noticed if ‘GLOB_VIEW_TYPE = 2’ is used (in master or parameter script) then whatever script is run after that command will run while in the library part editor.
For example …
IF GLOB_VIEW_TYPE = 2 THEN !do only in 2D
IF firstRun = 0 THEN !parameter that allow to run code only once
parameters firstRun = 1 !prevents running code again
ENDIF
ENDIFSo if there is a boolean parameter in the parameter list called ‘firstRun’ then it is automatically set to ‘1’ and you can’t manually change it.
If you alter the script to … IF GLOB_VIEW_TYPE = 3
or any other value then it is not run and you can manually change the parameter.Is this a bug that GLOB_VIEW_TYPE = 2 is ignored while in the library part editor? – seeing as technically it is not a 2D view and this part of the script should be ignored.
Just as it is ignored if GLOB_VIEW_TYPE = 3 (or any other value) is used.
Just finding it hard to see any logic here.To test this I used this code in the master script.
IF GLOB_VIEW_TYPE = 2 THEN !do only in 2D IF firstRun = 0 THEN !parameter that allow to run code only once parameters firstRun = 1 !prevents running code again ENDIF !SET STYLE "switch" !!! ---------- show Selector hotspot---------- HSID=HSID+1 hotspot2 0, 0 , HSID, firstRun, 1 ! base HSID=HSID+1 hotspot2 0,0-1 , HSID, firstRun, 3 ! ref HSID=HSID+1 hotspot2 0, firstRun, HSID, firstRun, 2 ! moving HSID=HSID+1 TEXT2 0,0,firstRun ENDIF IF GLOB_VIEW_TYPE = 3 THEN !do only in 2D IF firstRun = 0 THEN !parameter that allow to run code only once parameters firstRun = 1 !prevents running code again ENDIF !SET STYLE "switch" !!! ---------- show Selector hotspot---------- HSID=HSID+1 hotspot 0, 0,0 , HSID, firstRun, 1 ! base HSID=HSID+1 hotspot 0,0-1,0 , HSID, firstRun, 3 ! ref HSID=HSID+1 hotspot 0, firstRun,0, HSID, firstRun, 2 ! moving HSID=HSID+1 DEFINE STYLE "text" "Arial", 150, 5, 0 SET STYLE "text" TEXT 0.001,0,firstRun ENDIF
The hotspots in 2D and 3D views allow me to adjust the value.
So that is working fine.
However in the object settings dialogue the parameter can not be altered and it the script editor it can not be altered either unless I comment out the section for ‘GLOB_VIEW_TYPE = 2’I hope I have explained this problem OK.
It would be nice if there was.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantIs there no REQUEST for this?
This is as I thought – just hoping there may be some other trick.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI have no idea about the legalities but I would say if you are selling your objects and are prepared to provide support for them (bug fixes, upgrades) then by all means password protect them.
If you are not prepared to support them then don’t password protect. Allow others to maintain them in the future.I wouldn’t have a problem with all objects having their scripts password protected so long as the parameters were still editable.
A person may make an object and protect it but it will be useless to me as I may use different fills, pens, materials in my template that don’t suit their defaults for the object. I then have no way to edit the default parameter settings as they a locked together with the scripts. (yes I know I can set up favourites).Please Graphisoft at least allow us to still edit the default parameters even when an object is password protected.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantMaybe you do need to use ‘7’.
Here is the code I use to change the pitch on my barge object.
No problem stretching it to or from zero.r = 0.350 HSID = HSID +1 hotspot 0, 0, 0, HSID, Ptch_Inp, 6 !center of angle HSID = HSID +1 hotspot r, 0, 0, HSID, Ptch_Inp, 4+128 !base hotspot HSID = HSID +1 hotspot r * cos (Ptch_Inp), 0, r * sin (Ptch_Inp), HSID, Ptch_Inp, 5 !moving HSID = HSID +1 hotspot 0, -1, 0, HSID, Ptch_Inp, 7 !center of angle HSID = HSID +1
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantIf you define a material in a ‘Master_GDL’ file then they will automatically be available in the material list for all objects and elements.
No need to call them at all.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantTry doing the conversions in the master script rather than the 2D script.
Anything you calculate in the 2D script can only be used in the 2D script and the values can’t be used to be sent back as parameters.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitFebruary 18, 2016 at 02:40 in reply to: Attempting to add Transformations to IF/THEN statement #2271Barry KellyParticipantI have never used Imperial measurements in a script but I suspect what you have shown is incorrect.
ADD command requires just one value, you seem to have two for each.
There must be another way of writing it as one figure.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitFebruary 17, 2016 at 10:38 in reply to: Is there a way to query all Library Part names in the loaded Libraries? #2266Barry KellyParticipantWe don’t rarely use the Graphisoft libraries as we have our own custom library that suits our needs better.
I certainly would not call objects/macros in your libraries as I am aware they can change without me knowing what has changed.I am just getting into migrating objects this last week actually and have spotted the possible problem of migrating objects called by other objects.
But I am hoping that if I keep the original names then the call will still work.
I am aware that migrating an object with a new name is probably a more logical way to keep track of them but I am hoping keeping the same name solves the ‘CALL’ problem.
Obviously there will be problems if parameters have changed in the called object but that would apply if calling a place-able object or a macro. So I just have to be careful to update any called parameters in the master objects as well.
The biggest problem I am having at the moment is remembering/finding all the objects that call other objects/macros that I want to amend/migrate.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitFebruary 17, 2016 at 09:40 in reply to: Is there a way to query all Library Part names in the loaded Libraries? #2264Barry KellyParticipantTony,
Please never use placeable elements as macros, it can cause many problems.Such as?
I do this all the time and have not noticed any problems so far.Barry.
Dell Precision M6800 - i7 4700MQ @ 2.40GHz, 16GB RAM, AMD FirePro M6100 (2GB), Windows 7 64bitBarry KellyParticipantI for one have been wanting to be able to use the autotext values for years.
https://archicad-talk.graphisoft.com/viewtopic.php?p=159752&highlight=autotext#159752
https://archicad-talk.graphisoft.com/viewtopic.php?p=160358&highlight=autotext#160358Barry.
