Home › Forums › General discussions › Parameter A and B – original parameter › Reply To: Parameter A and B – original parameter
February 11, 2020 at 18:40
#18548
Hi Péter
We have a construction area with some buildings (building A, building B, building C). Know we want to place a survey map in the header of every plan, at the moment the
architect do this with the element below. He draw the survey map in the 2D-Symbol and change the list of the parameter “p_sicht_tab”. With the command MUL2 it’s possible
to change the size graphically, but I need the parameters orig_A & orig_B (At the moment we copy the parameter A & B manual in the parameterlist).
Maybe there is a better way to create this element, thank you in advance.
