Home › Forums › Problems and solutions in GDL › Doors and windows › Accessing all door parameters › Reply To: Accessing all door parameters
Then back in the master script I used the HIDEPARAMETER ALL command with my new title in quotes after the ALL and my new variables show up and can be edited.
Yes if you add parameter names after the ALL then they will show.
HIDEPARAMETER ALL – will hide ALL parameters
HIDEPARAMETER ALL [“name1” [, “name2”, …, “namen”]] – will hide ALL parameters except name1, name2, etc.
When you say all the scripts are blank except the master script, are they all empty or are the script buttons locked.
They may all be empty as the master script is CALLing another macro that has al the scripts.
The GS objects do a lot of CALLing other macros so it can sometimes be a bit tricky to follow exactly what is going on.
