Home › Forums › General discussions › Use fill from surface in 2D-symbol? › Reply To: Use fill from surface in 2D-symbol?
April 18, 2020 at 10:42
#18701
Mats Knutsson
A symbolic pattern. Should be diagonal (45 degrees) to the object. I use a regular ANSI fill. Will try to figure out how to code it according to James’s tips. I just would like to see a code example to learn from.
