Home › Forums › Problems and solutions in GDL › Object design › Show overlapping prisms / blocks as solid
- This topic has 1 reply, 2 voices, and was last updated 6 years, 1 month ago by
Péter Baksa.
September 23, 2019 at 14:51 #18218
James Goode
ParticipantHello,
I have created some hatching in 3D for one of our objects. This has been done by using a for I=1 to … function and then cut around the shape with cutpolya.
Because my lines overlap diagonally due to it being a crosshatch, when I use project2 3, 270, 2 in 2D, it shows the lines crossing over. Is there any way that I can get rid of the overlapping lines so that it looks like one continuous block rather than separate elements?
cutpolya 12, 1, 0, -50, -50, 15, 50, -50, 15, 50, 50, 15, -50, 50, 15, -50, -50, -1, line_width-ll, line_width-bl, 1, line_width-ll, B-line_width+tl, 1, margin-line_width/2, b-line_width+tl, 1, margin-line_width/2, margin-line_width/2, 1, A-line_width/2, margin-line_width/2, 1, A-line_width/2, line_width-bl, 1, line_width-ll, line_width-bl, -1 addy -4 rotz 45 for i=1 to 40 cprism_{4} mat_hatching, mat_hatching, mat_hatching, 7, 5, line_height, 0, 0, 0, 15, mat_hatching, 10, 0, 0, 15, mat_hatching, 10, hatching_width, 0, 15, mat_hatching, 0, hatching_width, 0, 15, mat_hatching, 0, 0, 0, -1, mat_hatching addy hatching_space next i DEL 40 DEL 2 addy 10 rotz -45 for i=1 to 40 cprism_{4} mat_hatching, mat_hatching, mat_hatching, 7, 5, line_height, 0, 0, 0, 15, mat_hatching, 10, 0, 0, 15, mat_hatching, 10, hatching_width, 0, 15, mat_hatching, 0, hatching_width, 0, 15, mat_hatching, 0, 0, 0, -1, mat_hatching addy -hatching_space next i DEL 40 DEL 2 CUTENDThanks
September 25, 2019 at 17:36 #18222
KeymasterHi,
the line elimination in mask of CPRISM_{3} only works when the edges are in the same place, it doesn’t calculate intersections.
Other ways to do it:
– model CPRISMs that only touch eachother
– write a loop that PUTs the hole coordinates in a large CPRISM
– use ADDGROUP, it removes lines at intersectionsPéter Baksa
