Home › Forums › Problems and solutions in GDL › Lists and schedules › Use Properties from Property Manager
- This topic has 9 replies, 5 voices, and was last updated 8 years, 5 months ago by
Gergely Fehér.
November 2, 2016 at 19:14 #2826
John Peterson
ParticipantI have previously created objects with custom parameters to use in schedules. I wish to exploit the new Excel round trip function of schedules. We often have consultants fill in things like electrical fixture schedules. To use the Excel round trip, I have to use Properties from the new Property Manager. I wish to read a property and then place it with the drawing symbol (or transfer to a parameter). For example, “Security Rating” from the “Openings” group. I thought the REQUEST (“Property_Name”, “id”, typeName, groupName, propertyName) would get me what I want, but it is poorly documented and when I finally got it working in the 2d script without errors, all I got was a 0 instead of the text that was in that property name for that object. Properties are great, but need some tools to use them.
Many thanks, JP
November 7, 2016 at 10:11 #2832
KeymasterRequests about properties only work with labels – as it is written in the documentation. (And zone stamps as they are working like labels). Properties should not take any effect on the 2d display (and 3d model) of any objects – except the visual override option outside GDL.
Everything which changes the symbol or model must be the library parts parameter – properties are just additional things attached to the element to store information about the library part.Gergely Fehér
November 24, 2016 at 16:43 #2888
ParticipantHow do I set up the script to use the Property Name as Value for a VALUES command in the new REQUEST (“Properties_Of_Parent) command (for a door marker)?
Following does not work:DIM _sTnCParamData[][5], _auswahl[], _parentProperties[] FOR i = 1 TO 5 _sTnCParamData[1][i] = "" NEXT i PROPERTY_FOLDER = 1 ! NEW: GROUP PROPERTY_ID = 2 ! NEW: ID PROPERTY_NAME = 3 ! NEW: NAME PROPERTY_VALUE = 4 ! NEW: VALUE PROPERTY_TYPE = 5 ! BRAND NEW TYPE n = REQUEST ("Properties_Of_Parent", "", _parentProperties) _numProperties = vardim1(_parentProperties) / 4 _sumParamNum = 1 for i = 1 to _numProperties _sTnCParamData[_sumParamNum][PROPERTY_FOLDER] = _parentProperties[4 * (i - 1) + 3] _sTnCParamData[_sumParamNum][PROPERTY_ID] = _parentProperties[4 * (i - 1) + 1] _sTnCParamData[_sumParamNum][PROPERTY_NAME] = _parentProperties[4 * (i - 1) + 4] _sTnCParamData[_sumParamNum][PROPERTY_VALUE] = "" _sTnCParamData[_sumParamNum][PROPERTY_TYPE] = _parentProperties[4 * (i - 1) + 2] _auswahl[_sumParamNum] = _sTnCParamData[_sumParamNum][PROPERTY_NAME] _sumParamNum = _sumParamNum + 1 next i VALUES "text_auswahl" _sTnCParamDataGDL Object Developer
MAC OSx 10.14 -
November 25, 2016 at 08:33 #2889
KeymasterThis request can not be used in parameter script, check it in the documentation please: “Expression returns 0 and contains dummy return values (emtpy string or 0) if used in parameter script, causing additional warning.”
Instead of this, you can use it in the ui script, and use the returned values in a custom popup infield, as it is written here: https://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels/
November 28, 2016 at 14:36 #2893
John Peterson
ParticipantThanks for the posts with help. I am basically trying to make a label placed with the object. The label is an identifier for the schedule. For example, a recessed light fixture with the label R1, R2 etcetera. Using a property allows the use of Excel round trip and the consultant can change the fixture identifier as required, and I would hope that could then update the label on the drawing. I was trying to read the value and then pace it with the text command in the 2d Script. I’ll read through your posts closer to use your suggestions. It doesn’t matter, but I don’t understand why Graphisoft had to place this restriction in the code. I’m sure it causes problems someplace.
Many thanks, JP
November 29, 2016 at 12:58 #2894
KeymasterEnabling these request in parameter scripts would cause problems: if you can reach properties in parameter script, then you can store them as parameter values. After placing an object and storing it’s parameters, you can easily change the properties – so the stored information will be outdated and can cause problems in lists and schedules, as there is no way to force parameter script run on all placed library parts in a whole project. Running all instances parameter script would be extremely slow in huge project and could affect the model appearance, which means a problem in background processing. And, if there would be a function to do that, you can’t do that in teamwork without reserving all library parts to make changes on their parameters…
November 30, 2016 at 17:02 #2899
John Peterson
ParticipantThank you. That makes sense to some extent. If you consider that currently you can have a schedule that has a connection to an objects parameters and has 2-way communication. Changes to the object effect the parameters, and object display. These values are then passed to the schedule and vice versa. The property is just a new player in the two way communication world. I just need to get a label of the property value onto the drawing next to the object. This label should be able to be updated in the object or the schedule and be updated on the drawing output. So all I was trying to do was to read the property value, and place it on the drawing with the text2 command. Seems like a simple request. Now I have to read the property value and then transfer it and then figure out how to place it. Still seems needlessly complicated, but I defer to the wisdom of the programmers who probably tried to make it work more directly and found the problem with that.
Many thanks, JP
December 14, 2016 at 05:06 #2924
Ben Cohen
ParticipantInstead of this, you can use it in the ui script, and use the returned values in a custom popup infield, as it is written here: https://gdl.graphisoft.com/tips-and-tricks/display-properties-with-labels/
Great tip!!thanks Gergely 🙂
May 24, 2017 at 15:17 #3266
ParticipantIn the case of an Option Set property that allows multiple choices, is there a way to offer the user the options that are in use by the element, so they can choose which option the label displays?
May 24, 2017 at 16:28 #3267
KeymasterJames,
Values should not be stored in parameter, as they can be changed without touching the object – so keeping the rules I think there is no real solution for that.
- The forum ‘Lists and schedules’ is closed to new topics and replies.
