Home › Forums › Problems and solutions in GDL › Graphical UI and parameters list › MASK in UI_PICT
- This topic has 10 replies, 4 voices, and was last updated 3 years, 6 months ago by
Nader Belal.
January 10, 2019 at 10:50 #4434
Vojtěch Janda
Participant -
January 10, 2019 at 11:26 #4437
Keymaster -
January 10, 2019 at 17:24 #4440
Vojtěch Janda
ParticipantThank you.
It works. But only with a jpg file. And how do I get the channel to show up in the user interface? With command UI_PICT?Thank you very much
January 10, 2019 at 21:02 #4442
ParticipantYes, UI_PICT with a 1 at the end instead of a 0.
Mask Value = 1
UI_PICT picture_reference, x, y [, width, height [, mask]]GDL Object Developer
MAC OSx 10.14 -
January 11, 2019 at 11:34 #4445
KeymasterHi Vojtěch,
I’ve tested it in AC22 and it works for me.
Which AC version are you using?
What do you mean by “The image is saved as a gsm object”?
What is the code to show the images?
Could you attach both the png and the jpg for testing?Péter Baksa
January 14, 2019 at 15:03 #4449
Vojtěch Janda
ParticipantHi Péter.
I attach png and pln file.
– I tested it in AC18 (windows and mac) and AC22 (mac). It is the same.
– I paste the image into ArchiCAD and save it as a library object. In this object, I write a 2D description and description of the user interface. (If the image is not part of the object but as the separate object, then everything is fine – See the fourth example)Thank you very much.
Here is the pln file: https://leteckaposta.cz/419529947
January 14, 2019 at 15:08 #4452
Vojtěch Janda
Participant -
January 15, 2019 at 10:43 #4457
KeymasterThanks, this looks like a bug, I will add it to the list.
There are other ways that you can use an image, no need to save it as gsm:
– add to the embedded library, it will be included in the pln/pla/teamwork file.
– put it in a folder, and add it as a library. Many plan files can access the pictures this way, all users have to have access to the folder.
– use the lp_xmlconverter tool to include an image in the libpart, just like saving as gsm. This works with transparent images (except jpg as ui_pict).Péter Baksa
January 15, 2019 at 12:40 #4458
Vojtěch Janda
I tried the LP_XMLConverter, but this way was easier.
So I will try the convertor again…Is there any video tutorial on LP_ XMLConverter?
Except: https://www.youtube.com/watch?v=wbucx37Leaswhat is meaning the command: “pathOfLP_XMLConverterExecuteable”
Path to the LP_XMLConverter?Thank you
January 15, 2019 at 14:25 #4459
KeymasterYes, “pathOfLP_XMLConverterExecuteable” is path including the executable, eg. “C:\ArchiCAD 22\LP_XMLConverter.exe”.
I don’t know about any training video on this.Péter Baksa
January 28, 2019 at 20:10 #4487
Nader Belal
Participant@Vojtěch Janda
when selecting the file path for conversion, and if you are in a Windows OS environment, just drag the file to the CMD window, it will write the full path and the file name in quotation marks (which is accepted by OS)
